Cermark MB339 pipe installation and some modification
1 Attachment(s)
Former for pipe mount.
Pipe install
1 Attachment(s)
Pipe install
Rear pipe install
1 Attachment(s)
Rear
Servos hatch
1 Attachment(s)
servos hacth
Servos for ele & rudder
1 Attachment(s)
servos ele & rud
heatshield install
1 Attachment(s)
heatshield install
heatshiled install
1 Attachment(s)
heatshield install
Just one elevator servo with a common torque rod for both halves, huh? Hard to tell from Tam's photos, but how beefey is that torque rod? Is this a robust design? Thanks guys.
Tams install
Mark,
I just got my arf kit and looking it over the torque rod assembly looks beefy enough. Tam has made a mod here. The elev and rudd servos are not that way in the instructions, they are up near the motor attached to the fuse sides with a long rod running back to the controls. I like Tams idea but the servos are very close to the tailpipe heat??. Vin... |
Tailpipe heat
Vince,
The pipe run pretty cool. There is no heat on the fiberclass. So the servos can handle it. If you want more protection for the servos. Put aluminum foil to protected. All the pipes will ship out today. All the customers bought Cermark or ED kit should have it next week. Tam |
Heat shield
Hi Tam will we get the heat shied and the former? thanks for the good mod tips ill stick with carbon rod if I were to go more power i would use the tam trik!!! Paul
| All times are GMT -8. The time now is 05:41 AM. |
