RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Kangaroo Help Needed (https://www.rcuniverse.com/forum/rc-jets-120/140510-kangaroo-help-needed.html)
mlevings 05-21-2002 07:41 PM
Hi guys, I am about to start building my Roo. I do not have the complete kit and could use a bit of help to get started. I have a hollow fuse with no formers or retract mounts installed. I have tracings of the gear openings on the way, but could use a couple of pictures of the retract mounts and how they are installed. I could also use a detailed picture of the wing tube installation in the fuse. That should be enough to get started. Thanks for the info.
Mark Levings
lov2flyrc 05-21-2002 07:56 PM
Check out my web site...Plenty of roo pics!
www.lov2flyrc.com Anything that is not there to visually help, email me and I will supply whatever you need.
Todd
bkf 05-21-2002 08:07 PM
Mark as soon as I wake up ill snap some pics for you. Then you tell me what angles from them you want to see. I had to do some more babysitting today as I talked to you about but should get the stuff off tomorrow. Let me check my picture files. Bkf
bkf 05-21-2002 08:18 PM
1 Attachment(s)
pic1
bkf 05-21-2002 08:19 PM
1 Attachment(s)
pic2
1 Attachment(s)
pic3
bkf 05-21-2002 08:20 PM
1 Attachment(s)
pic4
bkf 05-21-2002 08:31 PM
1 Attachment(s)
pic5
bkf 05-21-2002 08:32 PM
1 Attachment(s)
pic6
bkf 05-21-2002 08:33 PM
1 Attachment(s)
pic7
1 Attachment(s)
pic8
mlevings 05-21-2002 11:56 PM
Ken, thanks for the pictures and manual. That is exactly what I was looking for. I am curious what the opening on the bottom of the fuse at the back is for. I have not seen that on some of the others I have looked at.
Mark
bkf 05-22-2002 03:03 AM
Originally posted by mlevings
Ben, thanks for the pictures and manual. That is exactly what I was looking for. I am curious what the opening on the bottom of the fuse at the back is for. I have not seen that on some of the others I have looked at.
Mark
Mark: Remember I was going to use a Ram 500 in the begining but now have a P120. The hatch serves two things. First with the tiny size of the Ram the Roo would be nose heavy so the batteries would go in there for proper CG. The other is it makes life easyier when getting to things in the rear ie. dealing with the turbine mounting bolts and such. Ken Not Ben :D
mlevings 05-22-2002 02:24 PM
KEN, sorry about that. Thanks for the info. I am still undecided on a turbine so far. I have to save a few more pennies and see what I can afford. The hatch sounds like a great idea.
Mark
