RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Can digital and regular survos mix (https://www.rcuniverse.com/forum/rc-jets-120/143094-can-digital-regular-survos-mix.html)
jetspud 05-24-2002 12:43 PM
I am trying to finish my roo. I have Hitec digitals for the rudders and when I was trying to Y the rudders into the stearing (futaba 3001) The 3001 was going wacky. I unpluged the digitals and then it worked fine. Does anyone know why this is happening???
Or how to solve the problem??
David
kevinthoele 05-24-2002 02:22 PM
Mixing
David,
Try mixing your rudders to another channel as this will give you trim on the stering without trimming the rudders.
Kevin
Veritech 05-24-2002 02:37 PM
David,
I agree with Kevin, if you have the spare channels on your radio, plug teeh rudders into another channel, like 7 or 8, then mix it to your steering channel. That's how I did my Roo and it workd out great. I have a non-digital servo on the nose gear and 2 digital multiplexes on the ruddres.
This way trimming the steering is very easy and it will not effect your rudder trim.
Randy
