RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Help..a fix for warped surfaces (https://www.rcuniverse.com/forum/rc-jets-120/1487363-help-fix-warped-surfaces.html)
Mach1 02-01-2004 12:00 PM
After cutting out and glassing the elevons for a hotspot I find they have bowed lenghtwise.
Anybody have a good way of taking this bow out?
W.G. Hunter
GrayUK 02-01-2004 12:04 PM
RE: Help..a fix for warped surfaces
put them under load, against the warp, and warm them up with a heat gun, (carefully!)
Let them cool, still under load.
Hope that helps.
JetflyerJ 02-01-2004 12:08 PM
Hi There I just had that problem myself with the gear doors on my 16, a friend told me to heat them up with pressure as stated above and it worked perfect, the only thing I did after it was shaped properly was added a few carbon fiber Strips to make sure they stay that way and this morning whenb I cycled the gear they were perfect, took about 5 minutes on each door.
Hope it works........... Johnny Hernandez
