Turbine Starting
Can anyone tell me howe to start differant engines, with starter motor and without.
and is there always a small flame when starting??? |
RE: Turbine Starting
Volkan, i see 50 people have been to view this thread and NOT ONE has even bothered to give you 10mins of their time to answer so i'll help you.
i use both methods, my electric starter is a R/C car motor with a home machined coupling on the front and a piece of rubber to prevent metal to metal contact, the rubber is an extremely tight fit as you don't want it going into the engine, this has a 15amp microswitch taped to the side for on/off, this is a good method, built it myself and works a treat, cost was nothing. i also use a blower fan from a car, i went to a car scrap yard and took one off, cost about £6, well thats what i offered the bloke and he took it. this works really well for starting as i have rigged it up to two small 12v batteries to get 24v, i made an attachment to on the exit side of the blower to duct the air into an intake sized hole, i simply turn on the gas of the jet and ignite, then blow the air through the engine and start the fuel pump or in the case of an ECU controlled engine the ECU will detect rpm above 1000 and temp above 100degC and it'll begin the pump. regards flames on startup, there shouldn't really be any, if you are getting some then fuel is entering the engine at too high a rate of flow, if you have an ECU controlled engine then adjust this. if you are only getting small flames then your starter may not be spooling the rotor fast enough to ensure the compressor is doing it's job. hope this helps all the best Paul j http://www.microjets.co.uk |
I will chime in here, though I am no expert, I have two auto start turbines. Both start in a similar fashion, pretty much automated and hands off. The SJ 1200 begins with the small electric motor which spins the turbine up and then the "PowerMax" ignites. I usually see a small flame for a second or two when this happens, but as soon as the kerosene ignites and the engine stabilizes there is no visible flame. When I first got my turbine I saw more flame on the startup and as it turns out it was getting too much propane (my fault), and after a conversation with Ed and Kevin they corrected my sequence and it goes much smoother now for me. One of my friends had a T-500 which is very similar to my 750 and 1200. The start takes a minute and is very smooth with no significant visible flame unless you have previously filled the can with fuel in an unsuccessful start. I hope you find what little info I contributed useful, I am sure that more of the seasoned jet jocks could give you more info, but most are probably on their way to Florida Jets. Unfortunately for me, I have to work most of the week.
Tommy |
I would have given you my way of how to start an amt, but it isn't technical.:D
Laura |
Hi Laura! can you start a Harley the same way?
Jetcat & the new AMT start like a Harley hit the switch, bit more to the amt air start version !!!!!;):D
Turbines ok to start, wouldnt want to start my dads D/A for the fear of it eatting my hand:) Laura |
thanks for the help guys
| All times are GMT -8. The time now is 05:07 PM. |
