Fitting Size for Vent Line
What is the standard size fitting I should use on a fuel tank vent line?
I'm setting up my turbine fuel tank on my Reaper and want to make sure the vent line is large enough. Currently it is 1/8" diameter brass tubing. Should l go with something larger? thanks, JR |
RE: Fitting Size for Vent Line
JR
I just looked at the plans for the Facet and Kerry calls for 5/32" fittings all the way around. |
Gary,
Thanks for the information. Going to the drill press now to enlarge the opening. JR |
| All times are GMT -8. The time now is 06:45 PM. |
