RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   BVM Mixture Control Question (https://www.rcuniverse.com/forum/rc-jets-120/1645032-bvm-mixture-control-question.html)
RC Thumbs 03-21-2004 12:42 AM
Does the BVM Inflight Mixture Control valve have enough range to be used as a fuel shut off?
Scott
J roc 03-21-2004 02:47 AM
RE: BVM Mixture Control Question
No it doesn't. And leaning the engine out to kill it is a very bad idea.
Kaos1 03-21-2004 10:07 PM
I am installing a BVM inflight control on my OS 91/Dynamax and would handle this like I do with all of my other R/C planes, adjust the carb/servo so that the throttle trim tab closes the carb.
RC Thumbs 03-21-2004 10:11 PM
This isn't going on an application that has an R/C carb. It would have to work as a fuel shutoff.
CARS II 03-22-2004 12:17 AM
If you set it up the right way then try to use it to stop the engine by closing it all the way with the servo you only will end up with a lean engine.
what you are looking for is a way how to complete shot off the fuel flow, you could use a servo for that in a different way.
CARS II
viper1 03-22-2004 03:30 AM
Correct me if I'm wrong, but I think RC Thumbs has a fuel shut-off for a turbine in mind...?
RC Thumbs 03-22-2004 04:00 AM
........no, not for a turbine. 2-Stroke IC. I'm looking for an inflight mixture control that has enough range that it will shut off the fuel supply in addition to adjusting the mixture. One servo, one device.
The two inflight mixture controls out there that are the most popular are the BVM and the JMP. I have already talked with Mr. Cook on the JMP.
Any suggestions on servo opperated fuel cutoffs?
MMallory 03-22-2004 09:55 AM
Use the mixture to control flow and attach a simple rod with a "J" to the same servo so when the mixture is full lean the "J" pinches the line closed. Just like on the F1 planes.
Mark M.
RC Thumbs 03-24-2004 12:27 AM
1 Attachment(s)
Thanks Mark, that sounds like it would work great.
I did find a fuel shutoff/mixture control device from Fourmost #142. Anyone have experience with this product?
joeflyer 03-24-2004 08:26 PM
Perry makes a valve to turn smoke systems off & on that should do what you want. Check it out at
http://www.perrypumps.com/prod03.htm
Joe
RC Thumbs 03-24-2004 10:23 PM
Thanks Joe. I will check them out.
