Kangaroo II
Hello I would like to know which prop engine adn pusher prop i can use with the kangaroo ?
RE: Kangaroo II
Well, I installed once a moki 210 with the carb rotated 90 degrees to invert the rotation of
the engine with a normal apc 16 x 16. It flew , but it didn't fly as good as expected, and after about a dozen flights the plane was crashed in a inverted flat spin caused by his high trust line. Regards, Enrique |
| All times are GMT -8. The time now is 07:52 AM. |
