AV8R framed up
1 Attachment(s)
Just posting a few pics of my AV8R all framed up. Took alot of work to make the fuse straight, but it got done eventually.
I'll post more as I start covering this week. Anyone got a set of brakes or brake valves they don't need? |
RE: AV8R framed up
Looking good!
JR Gautreaux |
RE: AV8R framed up
just got back from running the FTE-500 for the first time.
Man that was simple. Great product. 5 starts and 250oz's later I'm still smiling |
RE: AV8R framed up
Shok, email me your address and I'll send you a set of wheels and brakes I'm never gonna use for $50.00. They should work perfect on an AV8R.
Sean |
RE: AV8R framed up
thanks Sean, much appreciated!
RE: AV8R framed up
1 Attachment(s)
and here it is after monokote, I did the covering job in 4 1/2 minutes.
I'm the new world champ! :D |
RE: AV8R framed up
i see some wrinkles
RE: AV8R framed up
I think you are imagining the wrinkles, this job is flawless
RE: AV8R framed up
Hey Shok where can I get a AV8R Kit?
RE: AV8R framed up
1 Attachment(s)
RE: AV8R framed up
Here is some video of the engine test run the otherday also
[link=http://www.rockwallrc.com/photos/jet2-1.wmv]FTE-500 run[/link] |
RE: AV8R framed up
I think you're going to like this plane :D
AJC |
RE: AV8R framed up
Shok
Here is some vid taken from mine http://www.rnlinc.com/rc/AV8R.wmv www.rnlinc.com Just make sure it is on the nose heavy side. As mine was way tail heavy when I got it. It flew ok but at the top of a loop it would go inverted flat. I just got very Lucky I got it out in time. Once cg moved to correct position the jet fly just fine, and if you attempt a loop too slow it will do a cool tail slide at the top where it runs out of speed, then the nose flops down and it flys right out! My FTE has run flawlessly every time and has almost unlimited vertical. Let me know if you have any questions. |
RE: AV8R framed up
thanks Don!
Cool video |
RE: AV8R framed up
1 Attachment(s)
wings covered now....it's getting close
RE: AV8R framed up
ok it's so close I can smell it now.
everything is hooked up and ready, all Im waiting on now is the brakes and the brake valve from glennis and it's time to go fly. Hopefully by the weekend if everything gets here. |
RE: AV8R framed up
ok all done now, hopefully can get some finished pics up soon.
All up weight is 13lbs even dry. 16.5lbs wet. so with a little math 837 Sq in, 16.5 Lb, 45Oz/Sq in at take offf, Stalling speed 37 mph 13 Lb, 36 Oz/Sq in at landing, Stalling speed 33mph This thing should be a breeze to fly. Now if the weather cooperates maybe I can maiden it Sunday. |
RE: AV8R framed up
Looks good Ronnie Hope we can fly it sunday.
Tom |
| All times are GMT -8. The time now is 06:18 AM. |
