RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Tailpipe projection (https://www.rcuniverse.com/forum/rc-jets-120/1970880-tailpipe-projection.html)
Dee Miller 07-08-2004 06:05 AM
Tailpipe projection
Should there be a projection beyond the tail of the plane (beyond the fiberglass) for
the outer pipe on a bypass system? If yes, then Why should it extend beyond the tail?
Dee
Darryl Usher 07-08-2004 09:41 AM
RE: Tailpipe projection
Outer duct should extend a little because until the ram effect of the inlet supples more air than the turbine can use, air is sucked in the rear.
Darryl Usher
Miguel Santana 07-08-2004 09:45 AM
No need to go beyond the tail.
Is ok with about 0.5 ~ 1 inch before the end, and cover that area with BVM heat shield.
This way it produce a diference in pressure that induce an cooling air flow inside the fuselage.
If you are using a double walled pipe from Tam ( the best), you can eather put the pipe flush with the rear of the fuse, but I consider is better not to do it.
Contact [email protected] , he will be happy to assist you.
Good Luck,
Miguel
Roger Shook 07-08-2004 08:43 PM
Assuming that you have an air gap between the outer pipe and the fuse, I agree it should actually stop short of the end of the fuse, but I would not go (1/2" or more) inside the fuse, more like 1/4 to 3/8" to create the differential pressure to draw some air through that air gap and cool the fuse a bit. the BVM heatshield in that area is a good idea as well.
Regards,
Roger Shook
aka: Rocky Mountain Turbine Tailpipes
MAX EFFFORT 07-08-2004 11:48 PM
TO PROTECT AGAINST DAMAGE [HANGER RASH] OR INJURY [ LIKE THE RAZOR CUT I RECEIVED],, A 1 QUART MAYONAISE LID FITS IN MY TAM PIPE PERFECTLY ,THEN I GLUED ON COOL [REMOVE BEFORE FLIGHT FLAG]
Miguel Santana 07-09-2004 08:11 AM
ORIGINAL: jetjock50
... but I would not go (1/2" or more) inside the fuse, more like 1/4 to 3/8" to create the differential pressure to draw some air through that air gap and cool the fuse a bit.
2nd thought: you're right....1/4 to 3/8 is ok ;)
Regards,
Miguel.-
