RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   JR10X- ELEVON QUESTION (https://www.rcuniverse.com/forum/rc-jets-120/1975561-jr10x-elevon-question.html)
MAX EFFFORT 07-09-2004 02:16 PM
My elevon set up is not working correctly and i can,t figure it out. the jr10x is new to me...here is prob,, when stick is pulled or pushed straight , elevons move .5 in. ,,,, when i push stick to side, elevons move 1in. .... mine and others opinion is that this is backwards.... i,ve gone over and over the book , tried travel adjustments in tx, reversed servos on tx , leads to rx ,etc.... left lead to aileron,,right to elevator on rx, as book says ..i,ve tried it the opposite too... i know there is something i,m missing in the book.. it needs more elevator movement than aileron doesn,t it ???... the a/c is , appropriately , a rookie, [me too] and its instructions just say 30mm or 1 in.+...they don,t specify when.... plzzz.:(. help!!!!! starting to pull hair...,, thnx if you can shed some light
Doug Cronkhite 07-09-2004 02:41 PM
RE: JR10X- ELEVON QUESTION
OK.. give me a rundown of your setup. Specifically:
Where are the servos plugged in?
What are the travel values in Code 12
What is set in Code 22 for Wing Type?
What is set in Code 14 for Trace Rate?
Also.. was this airplane setup in a fresh model memory? Do you have the Datasafe working? If you do, save your current program and PM it to me and I'll check it out.
MAX EFFFORT 07-10-2004 12:19 AM
i think i got it,, it was diff rate on 22 and trace rate on 14 , seems to be working closer to right way, thnx doug ,anyway any other tips welome..the book on this radio is tuff for me to figure out.
