Picture shrinking
can anyone out there tell me how or shrink a pic for me ?
thanks, Jermaine |
Picture shrinking
use the SMART SAVER from ULEAD.
It is a 30 days trial. Works perfect for JPEGS!! Goose |
Resizing
If you are running a Microsoft operating system (windows), it is likely that you already have Microsoft Photo Editor installed on your computer. Try searching your computer by entering "photo" in the filename search. If you have this program, or something similar, after you open your file click "resize" and then save your photo with a new name. Check the help menu to find out more about options for saving your files. The "quality factor" or "compression" will determine your file size. You need to experiment with this by saving the photo using different factors with different file names and then reopening the files. If you are posting here, you want to keep the file big enough to retain resolution, but no more than 700x700 pixels and a maximum of a 80kbyte file size. Use jpg format for saving pictures.
Picture shrinking
If all else fails, send them to me and I will shrink them for you:D But your computer should have some sort of photo software in it....
I know
TRY PUTTING YOUR PICTURE IN MY WASHING MACHINE.
My wife does a really good job of shrinking everything! Or try your washing machine and line dry only! (no bleach) |
Picture shrinking
Thats Great Test pilot !!!!
I love it |
Shrinking
Ice cold water seems to work for some things.
| All times are GMT -8. The time now is 07:16 PM. |
