RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Kingcat/ P120 Setup Question (https://www.rcuniverse.com/forum/rc-jets-120/2087528-kingcat-p120-setup-question.html)
IFLYBVM2 08-15-2004 04:44 PM
Hi Guys-Where inside the jet are you guys putting the propane tank for the P120/Kingcat setup?
rhklenke 08-15-2004 05:22 PM
RE: Kingcat/ P120 Setup Question
I just stuck a loop of veltye (double-sided velcro) to the side of the fuse back between the aft end of the component board and the UAT/fuel tanks and used that to secured it there. Its really light, so its not like it has to be securely mounted in a fixed position.
Bob
booker-RCU 08-15-2004 05:43 PM
1 Attachment(s)
I extended the componet board by adding a piece of plywood between the end of the origional componet board and the cross brace for the fuel tanks and uat. I made a hole large enough to put the tank thru and then put large o-rings on top and bottom of the board to hold the tank. This made extra room for mounting the smoke pump and the fuel and smoke manual shout off valves.
(Adding the extra componet board was Al Watsons Idea)
Galen
Harley Condra 08-15-2004 11:20 PM
Mine is just ahead of the header tank, right beside the UAT. A small amount of foam padding holds it in place.
Harley Condra
BVM REP
Team JetCat
pilott28 08-16-2004 09:15 PM
Mine sits in a piece of foam between the main tanks. K.
