DF Conversion Turbine Mounting
1 Attachment(s)
I have just got hold of a PJP Eurofighter. I am still at the planning stage at the moment.
It is the turbine version of the kit that was originally designed for DF power. I think the only difference is that it comes with a rather nice twin walled metal tail pipe. The inlet ducts look to be the standard DF Epoxy ducts. I am planning on using a Wren 54 (possibly Mk3) My questions are. Where do I mount the turbine? How far behind the inlet duct should the engine be? Should the tailcone of the engine be inside or in front of the tailpipe? Should I use a bypass? Will it be of benefit to do so? Do I need to heat protect the rear of the Epoxy fuselage? Thanks |
RE: DF Conversion Turbine Mounting
please post some pics of the kit itself ;)
| All times are GMT -8. The time now is 12:20 PM. |
