MB339 ARF's
I know this has been posted before here...but not a whole lot
of info on how they fly . I want to put a RAM 500x in one. Whats the speed envelope with this setup? Thanks W.G.Hunter |
MB339
1 Attachment(s)
mach1- Not sure myself yet? I will be installing a PST 600 very soon in my MB339. Tam has said his one flies great at 21 lb with the RAM500 + smoke, and is quite quick.... Slow end should be very good if AUW is kept down. It has a ton of wing area + big flaps, so I am not worried about landings. I hope to fly it off grass as well. : )
MACCHI colours
1 Attachment(s)
And here is my chosen paint scheme- RAAF Roulettes for my ARF MB339 although the Roulettes flew an earlier MB 326, I like the colours and it will do me!!
Re: MB339
Originally posted by ozcan mach1- Not sure myself yet? I will be installing a PST 600 very soon in my MB339. Tam has said his one flies great at 21 lb with the RAM500 + smoke, and is quite quick.... Slow end should be very good if AUW is kept down. It has a ton of wing area + big flaps, so I am not worried about landings. I hope to fly it off grass as well. : ) Take off weight 21 lb with 25oz smoke and 78oz of fuel. My assemble kit little heavier than stock. You noticed I reinforce main formers, stabs, fins, landing gear block. Brg, Tam |
mb339
I have a kit built that I intend on flying within the week. It has a simjet 1200 in it. with 60 oz of fuel. Empty it is 15.5 pounds. I think it will be perfect with this size of turbine. I will let you all know how it does.
| All times are GMT -8. The time now is 05:35 AM. |
