Aggressor III CG
A friend here picked up an Aggressor III and asked me to see if anyone here knows where the CG should be and what the throws are. Is there somewhere online that I can find the instruction book for this plane?
Thanks! Gene |
RE: Aggressor III CG
Hey gene, i have a set of plans i would sell if your friend is intrested. 20.00 shipped. just let me know, Ben
Call Patty at BVM . She will give you the info..........for free.
407-327-6333 Mickey A-1 Hobby |
Gene,
It's not in the instruction book. I just called Patty 2 days ago for the same information. 5 3/4" from the leading edge at the root. I hope to test fly mine this weekend. If your plane isn't built, get the plans they will help. Mark M. |
I almost forgot:
Takeoff flaps 10 - 15 degrees Full flap 30 degree with 1/16" down elevator Elevator 5/8" up & down Aileron 1/2" up & 5/16 down nose 20 degrees travel Rudder 3/4" Aileron servo arm set 10 degrees forward at neutral. 1st flight do not use flaps. Trim at 1/2 throttle. All of this from the 12/93 manual. Mark |
Thanks for the information! I will tell him about the plans also.
Gene |
| All times are GMT -8. The time now is 08:47 AM. |
