Questions
Hey all. I know i am way out of my league here as a begginer that has never flown before but i have a few questions because in the future when i am ready.. (year or two maybe) I would like to get into jets. I'm sure most or all of you started with regular single engine prop planes, and i'd just like to know...
1: How much different are jets form regular RC planes? 2: What is the US dollar amount spent on a complete aircraft from purchase to first flight? 3: Seems like BVM has the best program for getting people flying jets, How would you all rate that assesment? 4: What is the dificulty level in flying a jet vs a regular plane? i know its more involved on the technical end but i am refering to actual flight. With the speeds that can me reached and the altitudes, how hard is it to stay oriented to your plane and keep track of its direction, pitch, roll, and yaw? 5: At what point of experiance would you recomend some one getting into flying jets? 1 year, 2 years? Any other info you all could provide would be great. I just spent the last hour or so searching the internet for pictures and videos of jet flight most of what came back was BVM stuff and I have to say, I'm hooked and definatly want to try it at some point. |
RE: Questions
There is a lot of info in this thread
http://www.rcuniverse.com/forum/m_11...tm.htm#1109761 As for BVM, he's got some great stuff, but I wouldn't agree with your comment about being best, he's expensive and his stuff works, but there are lots of other great jets out there. Dollar amount, probably $4000 on the low end (if you have nothing already) to as much as you want to spend. |
RE: Questions
1: How much different are jets form regular RC planes? 2: What is the US dollar amount spent on a complete aircraft from purchase to first flight? 3: Seems like BVM has the best program for getting people flying jets, How would you all rate that assesment? 4: What is the dificulty level in flying a jet vs a regular plane? i know its more involved on the technical end but i am refering to actual flight. With the speeds that can me reached and the altitudes, how hard is it to stay oriented to your plane and keep track of its direction, pitch, roll, and yaw? I've only been flying for a very short time and only solo'ed my Harpoon just a few weeks ago. I had a lot of anxiety on the run up to my first flights but afterwards I was wondering what all the fuss was about. I've found that flying, orientation, etc, is easier than with some of my small, twitchy, IC powered models - simply because it's a bigger model. It doesn't get buffeted by the wind (quite so much), it flies much smoother, and you can see it much easier. Judging "depth of vision" is going to take a bit of work because if you've been flying smaller models then I found that you tend to fly larger models further away from you - on the finals before landing I found that I was not even over the strip and that I was actually on the other side of it and had to go around and line up again. Probably one of the main differences is that jet models need airspeed in order to fly. There is no prop wash and the throttle response isn't near instantaneous like it is on an IC prop model. If you decide that you need to go around after a botched approach then you have to resist the temptation to whack the throttle open and simultaneously haul on the elevator - you have to throttle up, wait a bit, and then be gentle and climb out smoothly. Fly with deliberation. 5: At what point of experiance would you recomend some one getting into flying jets? 1 year, 2 years? Any other info you all could provide would be great. I just spent the last hour or so searching the internet for pictures and videos of jet flight most of what came back was BVM stuff and I have to say, I'm hooked and definatly want to try it at some point. http://www.rainman.uklinux.net/movies/Harpoon_solo.wmv Good luck! Phil |
RE: Questions
Thanks guys and that was a good video Phil. I found that i lost track of the plane several times and that is what i would be afraid of doing if i was flying it. I guess with time one gets better.
Thanks again for the info. If any one else has anything to add please do. I would love to read others thoughts. |
RE: Questions
Shadukar,
Don't let the video fool you. I lose track of them in video's as well. BUT, a video is not life size. It's very different when you are at the flying field watching these fly. They are much easier to see at the field than compared to the video. My .02. :D:D |
RE: Questions
It is not very different at all, the problem is to develop the "sixth sense" to properly fly a jet at a greater speeds and distances without a big wing as a visual reference, and know how to control at low speeds a airplane with a higher wing loading , turbine lag time and no propeller airflow on the control surfaces... You can give a try in a flight simulator like Realflight g2 and fly a extra 300 and later a F-16 to have some idea.
Rgds, Enrique |
| All times are GMT -8. The time now is 12:02 AM. |
