RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   NEW GUY NEEDS HELP (https://www.rcuniverse.com/forum/rc-jets-120/2258587-new-guy-needs-help.html)
chipperg 10-16-2004 04:33 AM
NEW GUY NEEDS HELP
NEW GUY NEEDS HELP. I HAVE A YELLOW AIRCRAFT F-18 WITH A WREN54 MK3 KIT. DOSE ANYBODY HAVE ANY INFO ON THIS SET UP.
Global10 10-16-2004 06:37 AM
RE: NEW GUY NEEDS HELP
Contact Shaun @ Yellow Aircraft or Tam, they should have the info your seeking. You can also be more specific as to what it is your looking for and someone may be able to help you out here.
yeahbaby 10-16-2004 07:18 AM
Have you tried to contact some of the Georgia Jets guys? talk about a ton of info and experience.
you can also look up "cowdog" or "kevin East" both of these guys had similiar setups in the SE Hornet.
do a search. there should be a good bit of info on RCU regarding this aircraft and engine combo.
just go to search and type in Yellow Aircraft Single engine hornet or Wren 54 Hornet and you'll be suprised what you find.
call or PM "Yellow Aircraft" aka Shaun Evans and he'll point you in the right direction.
hasta
buck
chipperg 10-16-2004 09:34 AM
THANKS FOR THE INFO IT HELPED A LOT. DOSE ANY BODY KNOW OF A PLACE I CAN GET SOME TURBINE TRAINNING? I LIVE IN GA AND I TRIED TO CONTACT THE JET GUYS IN ATLANTA BUT I COULD NOT FIND ANY CONTACT INFO. DO I NEED A SIGN OFF TO FLY MY JET. I HAVE FLOWN DF FOR AWHILE BUT MY FIELD IS 500 AC OF SOD SO NO AMA. THANKS
yeahbaby 10-16-2004 09:37 AM
do a google search "Georgia Jets" or go to Jetadic.com and look under links.
good luck
buck
bcovish 10-16-2004 09:50 AM
go to www.georgiajets.org They are located in the Atlanta area.
