RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   RAM 500 Batt (https://www.rcuniverse.com/forum/rc-jets-120/226204-ram-500-batt.html)
uncleTom 08-12-2002 01:25 AM
RAM 500 Batt
What is the right size Batt. for my ECU :confused:
Carlos RTI 08-14-2002 02:00 AM
RAM 500 Batt
Tom,
It is recommended to use a 7.2v/1400MAH with the 500 ECU. I have it in stock if you need one.
rjpmodel 01-12-2003 04:15 AM
RAM 500 Batt
The newer red battery that we changed to with the X-series engines is always the better battery even for the older systems. It uses the red SRC low impedance 1250 cells. These cells have 1/2 the internal impedance(resistance) of the 1400's previously used. The capacity is slightly lower but the lower internal resistance keeps the voltage from dropping as far when the high current starter motor comes on. I am pretty sure Carlos has these available also.
