https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
It comes with a small set of screws to put it together. I just used the same diameter screw but longer and went fully into the inclosure to mount it with a set of aircraft nuts on the inside. I also cut off the plastic "feet" on the bottom so it mounted more flush.
Originally Posted by Air Works
(Post 12463559)
Hi Kevin do you have the item number for the digital voltage regulator?
Thanks |
Originally Posted by kevin
(Post 12463594)
It comes with a small set of screws to put it together. I just used the same diameter screw but longer and went fully into the inclosure to mount it with a set of aircraft nuts on the inside. I also cut off the plastic "feet" on the bottom so it mounted more flush. |
Built one for smoke oil. Works great, thank you for the good idea.
https://cimg7.ibsrv.net/gimg/www.rcu...6b7a822a7d.jpg |
Originally Posted by F16Jeff
(Post 12469080)
https://cimg7.ibsrv.net/gimg/www.rcu...6b7a822a7d.jpg Looks great! Glad it worked for you. Bought another regulator a few weeks ago in anticipation of building another one for smoke... |
