RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Zero Slop Linkage (https://www.rcuniverse.com/forum/rc-jets-120/235721-zero-slop-linkage.html)
I-NAV 08-19-2002 06:02 AM
Zero Slop Linkage
Trying to reduce the play on my F-22 stabs. Replaced the gears on the 8411s with the plastic set and that cut the play in half. What are you all using on the servo end for arms and linkage? Tried the dubro items but they are plastic and too weak.
tp777fo 08-20-2002 01:23 AM
Slop
Mike,
Use H-9 aluminum arms on the servo with Rocket City 4-40 ball link screwed into them. Put a nut behind the bolt to give double safe attachment. Do the same on the other end where it attaches to the stab. The nylon ball links wont allow any rotation on the pushrod, you might even place a jam nut just for the comfort level. My Su-31 is dead tight - absolutely no wiggle at all.
Tom
