RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Answer the Question / Ask a new question - Game (https://www.rcuniverse.com/forum/rc-jets-120/2395838-answer-question-ask-new-question-game.html)
jetflyer 12-02-2004 04:10 PM
Ok, things have gotten pretty boring around here. How about a game? First you answer the question from the previous post, then you can ask a question. The next person posting to this post must do the same (Answer the previous question and post a new one).
Let's keep the questions somewhat jet related and see if we can't pass around some good information.
Ok here it goes, I'll start this off....
Question: Describe a few things to check for while doing "Pre-flight" check at the field.
JR Gautreaux
MLaCoste 12-02-2004 04:27 PM
RE: Answer the Question / Ask a new question - Game
Besides all the normal stuff.......remembering to open the manual shut off valve BEFORE initiating an engine start [X(]
I forget about every other flight!!!
Mark
jetflyer 12-02-2004 04:30 PM
Mark,
You forgot to ask new queston after answering the previous one. If someone else posts to this post, please ask a new question.
JR Gautreaux
MLaCoste 12-02-2004 04:41 PM
Oops!
Okay, the new question:
Just picked up a Tamjets/ Cermark ViperJet MkII at our clubs' Field Relocation Super Raffle....:D For those of you that have one of these, what suggestions do you have for setting this bad boy up?
MAX EFFFORT 12-02-2004 04:46 PM
answer --call tam.............. new question --- for 200 dollars--, what and when was the first full scale jet that could hovered and then transist to normal flight? [clue-- nasa history]
lex2bits 12-02-2004 06:03 PM
A. Bell X-14, 1957
Q. Do base loaded Tx antennae work with base loaded Rx antennae (Deans, Revolution,etc)?
Lt. Dan 12-02-2004 06:06 PM
1 Attachment(s)
ORIGINAL: daytona kid
I'm gonna say: The very ugly, Ryan X-13 Vertijet?
Question: When the FMC goes into overspeed protection and lowers the MMO upper foot suddenly during flight, what could be the possible cause? [hint, its fuel system related]
lex2bits 12-02-2004 06:21 PM
Well, we are both correct Dan.
The X-13 was a "tail sitter" and made it's first complete cycle in 1957.
The X-14 was a Harrier type (conventional and VTOL), also first complete cycle in 1957.
Daytona... You can make checks out to both Dan & I, we will PM you our addresses.
Lex :D
jetflyer 12-02-2004 06:58 PM
Sweet guys, now keep it going and hopefully other RCU'ers will join in the fun.
JR Gautreaux
Kevin Cox 12-02-2004 07:19 PM
You last two forgot to ask a question :)
Question: How much fuel does the smaller turbines ( like Wren 44) carry on-board and what is the typical flight time?
MAX EFFFORT 12-02-2004 10:42 PM
sorry lex,, i was thinkin x-13.. not sure myself now,,both can,t be first tho ....would be intresting to find out which, for sure.. but since i was thinkin x-13 i,m giving it to dan..good try tho
MAX EFFFORT 12-02-2004 10:51 PM
first guess.. leak in fuel system?..2nd guess.. engine fire?
lex2bits 12-03-2004 12:02 AM
Well, as it turns out, my recollection was off a bit. The X-14 didn't do the full cycle until May '58, while the X-13 cycled in April '57.
Congrat's Dan, don't spend it all in one place.
Lex :D
Lt. Dan 12-03-2004 12:19 AM
[link=http://www.wpafb.af.mil/museum/modern_flight/mf34.htm]Here's the answer [/link]
The airplane made history on April 11, 1957, when it completed its first full-cycle flight at Edwards AFB, California. It took off vertically from its mobile trailer, rose into the air, nosed over into a level attitude, and flew for several minutes. It then reversed the procedure to vertical flight and slowly descended to its trailer for a safe landing.
I'll collect the $200 from you next time we fly. :D
Wayne22 12-03-2004 12:33 AM
50 oz Dubro tank is not uncommon..I'm guessing 8 or 9 minutes but won't know for sure until spring thaw...
My question: Has anyone ever experienced a turbine wheel throwing a blade, and if so, what was the result?
Gazzer 12-03-2004 08:27 AM
Answer: yes they have and the result was devastating!!! (Recent RCJI Y/A F15 review on an early KJ66 wheel).
Question: Why have the manufacturers stopped making Kevlar burst protection shrouds for the bypass units?
Can we work in British pounds for my next win though???
Gazzer
