RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Hot Spot Neutral Position (https://www.rcuniverse.com/forum/rc-jets-120/2427382-hot-spot-neutral-position.html)
McclureMitch 12-12-2004 08:36 PM
Hi,
Just finished my Hot Spot and would like to know what the throws are.
Randy M. 12-12-2004 10:47 PM
RE: Hot Spot Neutral Position
From the manual, ver batem;
In the basic setting for normal flight, the elevons must be up (reflexed) by about 5-7mm, measured at the root trailing edge.
All control surface travels should be measured at the trailing edge. Maximum travels should be 30mm up, 25mm down.
Aileron alone +/- 12 -15mm
Elevator alone 20-25mm up
20-25mm down.
Hope this helps, Randy
erbroens 12-13-2004 09:27 AM
Good HS info :
http://www.rcuniverse.com/forum/m_23...tm.htm#2375917
Rgds, Enrique
McclureMitch 12-13-2004 06:06 PM
Thank you Randy & Enrique.
snow snow snow [:@] I want to test it now :D
private 12-13-2004 09:05 PM
Hi,
I was wondering if I coudl test fly my hot spot with a 2 stroke motor before strapping on a jetcat? Thanks for any info
erbroens 12-13-2004 11:11 PM
I flew a HS with a Moki 2.10 as a test and it was awful... don't waste your time doing this.
Regards, Enrique
