A380 UNVEILED!!
Check it out:
http://www.airbus.com/A380/Default2.aspx?ArtId=373 i heard it will madien in early 2005, any1 know when? http://www.airbus.com/A380/Images/MME/1679.JPG http://www.airbus.com/A380/Images/MME/1675.JPG http://www.airbus.com/A380/Images/MME/1682.JPG |
RE: A380 UNVEILED!!
Outstanding!
I hope they got it right, I know they've been working on structural re-designs for a long time. Sure is an awesome beast though!!! |
RE: A380 UNVEILED!!
'spose it's quite big.
RE: A380 UNVEILED!!
Up to 800 passengers in one aircraft ... cool - now I can spend 2 hours waiting to board, and 2 hours waiting in line to get off the airplane after it arrives at its destination. [:o]
RE: A380 UNVEILED!!
ORIGINAL: Gordon Mc Up to 800 passengers in one aircraft ... cool - now I can spend 2 hours waiting to board, and 2 hours waiting in line to get off the airplane after it arrives at its destination. [:o] 900+ I think most airlines will do that in about 10-15 years. There should be a limit. what if a A380 with 900 passengers crashes:eek:? enough said. |
RE: A380 UNVEILED!!
now I can spend 2 hours waiting to board, and 2 hours waiting in line to get off the airplane after it arrives at its destination. |
RE: A380 UNVEILED!!
There should be a limit. what if a A380 with 900 passengers crashes:eek:? enough said. 2hrs to get on and off............you wont have that problem........... |
RE: A380 UNVEILED!!
ORIGINAL: nony now I can spend 2 hours waiting to board, and 2 hours waiting in line to get off the airplane after it arrives at its destination. Dave Rigotti |
RE: A380 UNVEILED!!
Now that's one BFA!!!
Going to require all new ground handling facilities - eight upper and lower level jetways, (Let's see if they can do a Southwest airlines 10 minute turn! :D)... If you throw 800+ passengers into an airport in a single shot, it will REALLY cause some problems in today's facilites. To keep passenger flow comparable to what it is today, luggage handling, passenger service and conveyence on the ground will need to be beefed up... Security screening will have to be doubled... going to need massive pax holding areas and increased departure gate facilities.. Reckon they discussed these "details" with airlines and airports... Seems the airports would have to start making aiprort improvements YESTERDAY to accomodate the airplane, which will likely be certified in 18-24 months.... But those improvements depend on who's gonna buy it and where are they gonna fly it? Things that make you go hmm... Cheers! Jim |
RE: A380 UNVEILED!!
ORIGINAL: Gordon Mc Up to 800 passengers in one aircraft ... cool - now I can spend 2 hours waiting to board, and 2 hours waiting in line to get off the airplane after it arrives at its destination. [:o] |
RE: A380 UNVEILED!!
RE: A380 UNVEILED!!
Reckon they discussed these "details" with airlines and airports... Seems the airports would have to start making aiprort improvements YESTERDAY to accomodate the airplane, which will likely be certified in 18-24 months.... But those improvements depend on who's gonna buy it and where are they gonna fly it? Things that make you go hmm... Cheers Ken |
RE: A380 UNVEILED!!
ORIGINAL: Jimmbbo If you throw 800+ passengers into an airport in a single shot, it will REALLY cause some problems in today's facilites. Cheers! Jim |
RE: A380 UNVEILED!!
ORIGINAL: Spartan Missile ORIGINAL: Jimmbbo If you throw 800+ passengers into an airport in a single shot, it will REALLY cause some problems in today's facilites. Cheers! Jim LOL Your not far off the mark there............average pax weights have increased, particularly on our flts to/from the US. |
RE: A380 UNVEILED!!
I heard they were going to have to bulid new/stronger runways for this thing.
Mike |
RE: A380 UNVEILED!!
one of the channels, discovery or tlc, but one of them had a segment on this plane the other nite, showing off the inside of this plane, very nice, they also said, Fed-Ex ordered 8 of them already. and they showed the ordeal on how they were made, all the pieces made in different locations then assembled in one big hanger, even showed how they transport the pieces thru town, and how the towns people get all excited about the parts going thru town, interesting to see how they did that
mark |
RE: A380 UNVEILED!!
That is the worlds biggest, fastest, instant soccerfield maker I have ever seen,WOW!!!
Skeet |
RE: A380 UNVEILED!!
1 Attachment(s)
SIA will take "fat" bus home in early 2006 and be first operator to this type!
Let see what is the coming test results (over-fat, blood pressure..... Maybe worth a look first in due after my last experience C-5 was here to deliver some.....here. Our National paper run a headline of this air "city" today, it have a lift on the rear from lower deck to upper deck! A lift......[:-] Do anyone have an idea, is 380 a distant "relative" of...[img][/img]:D regards Albert |
RE: A380 UNVEILED!!
Best thing for me about Airbus products is you end up with most of your hearing still intact after a long flight. They do know how to make quiet airplanes. Also a lot quieter on the ground than them Boeings. The real numbers for the A380 seem to indicate that with the same passenger volume you only need half the flights, considerably easing the strain in terms of safety of existing infratructure.
Good work Europe! And then of course there is the massive Arian 5 from "old europe" Andre |
RE: A380 UNVEILED!!
why is there so much negative comments about the A380? pls stop cursing it if you do not like it, eg saying it would crash. It is not nice. If you do not like it, so be it, but pls do not say anything about crashing.
RE: A380 UNVEILED!!
That is one big horrible jetliner, but still a masterpeice. I wonder if Howard Hughes had anything to do with it, had anything to do with it, had anything to do with it, had anything to do with it, had anything to do with it, had anything to do with it, had anything to do with it, had anything to do with it, had anything to do with it.
They should call it the carbon goose. |
RE: A380 UNVEILED!!
FlyRCU said : why is there so much negative comments about the A380?
Easy one...'Cause it's not a BOEING plane.... |
RE: A380 UNVEILED!!
conversation with A380 attendant while onboard in coach-
Umm stewardess? Yes? Whats going on in first class? They are crashing! Crashing! Yes, we have been crashing for the last five minutes- But don't worry we have ten more minutes until we crash.. |
RE: A380 UNVEILED!!
Quick Math:
Just doing some calculation here -If you could weigh the air inside the airbus it would be about 2285 pounds. or three american passengers.. |
RE: A380 UNVEILED!!
ORIGINAL: Glorfindel FlyRCU said : why is there so much negative comments about the A380? Easy one...'Cause it's not a BOEING plane.... |
| All times are GMT -8. The time now is 01:25 AM. |
