RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Duralites (https://www.rcuniverse.com/forum/rc-jets-120/2611488-duralites.html)
frankie 02-02-2005 12:09 AM
Duralites
Hello guys - is there anybody out there who owns Duralite Lithium-Ion battery packs and is charging then sucessfully using the Shulze 330d charger?
If you are using this charger are you using the "charge safe" lead or the direct power lead?
If using these batteries for reciever power, how many packs, what size/cell count are you using, and how many milliamps are you putting into each batterey for a flying session?
Thanks in advance, regards Frank L
pilott28 02-02-2005 09:09 PM
RE: Duralites
Lithium Ion setting, two cells, charge at 1C. Check to make sure you have the version 8 software. Mine is 8.06.
The cells must be fairly well discharged, otherwise the 330d will see the peak cutoff voltage when you start and you won't get a charge.
frankie 02-04-2005 12:09 AM
RE: Duralites
Thanks for the reply, much appreciated - however, which battery lead on the Duralite pack do you connect to? Do you bypass the "charge only" lead and go for the direct connection as you are not using a duralite charger?
Thank you, Frank L
pilott28 02-04-2005 11:35 PM
RE: Duralites
I charge directly into the cells
