RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   P-80 Engine Mount (https://www.rcuniverse.com/forum/rc-jets-120/2624646-p-80-engine-mount.html)
Chas 02-05-2005 04:32 PM
P-80 Engine Mount
Hi, this might be a dumb question, but I am new to turbines. I have a new P-80 and put the factory mount on and were the 2 haves meet they make small indentations in the chrome housing. Is this normal or do I have somthing to worry about?? At the cost of this thing, I thought I would ask, as I can't call Jetcat till Monday.
Thanks.
Chuck.
Vincent 02-05-2005 05:21 PM
RE: P-80 Engine Mount
Marks on the motor case?? you don`t need to crunch the clamp down super tight, just snug.
V..
matten 02-05-2005 05:32 PM
I did the same as you when I mounted my p-80 on my first Jet, got some small marks on the case, now it is powering my third jet and never had a problem with it, I do not think that there is anithing to worry about, but like Vincent says, just make it snug........
Regards,
RM
Chas 02-06-2005 06:51 AM
Thanks Guys for the input. After looking the mount over closer, I see it was not that the 2 piece mount was not over tighten, The mounting tabs were not a perfect 90 degree to the bottom mount. So when I screwed it to a flat surface it put a little more pressure right at the spot were the 2 half's meet.
Chuck.
John Redman 02-06-2005 12:34 PM
sent you a pm chuck.
