Another Reaction 54
1 Attachment(s)
Here's my Reaction 54 after 2 weekends and 1 week of evenings. All I can say is this is a nice kit. The manual is very well done and the plans and parts are accurate. I figure about 1 more weekend and it will be ready for covering.
Gary |
RE: Another Reaction 54
ORIGINAL: Gary Szetlak Here's my Reaction 54 after 2 weekends and 1 week of evenings. All I can say is this is a nice kit. The manual is very well done and the plans and parts are accurate. I figure about 1 more weekend and it will be ready for covering. Gary Looking good! What turbine are you going to use? My R54 has a P60 and is almost ready to fly. I'm in Chesterland...Far East side Dave Rigotti |
Nice!
this plane is begging for tip tanks, a canopy and a navy scheme.... Regards, Enrique |
Simjet 1200 for power. I will be using BVM wheels and brakes, I have to make some sort of adapter however to have them work on the wire struts but that shouldn't be to bad.
Gary |
Gary
Just by the 3/16 axle adaptors from BVM. They have the solid block that allows the brake hub to lock into. Used that set up on my BVM Maverick for years. Dean Wichmann www.helijet.ca |
sorry dean...you can't do that....i thought of that already.....if you cut off the axle portion of the pre-bent struts, then the remaining strut wire is too short to get the proper height......
Rich, have you looked at using a set of BVM wire struts to replace those that came with the gear? That is what I plan to do but haven't looked at it yet to see if you can do that.
| All times are GMT -8. The time now is 02:11 PM. |
