RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   CG for Hotspot (https://www.rcuniverse.com/forum/rc-jets-120/270977-cg-hotspot.html)
Brandon-RCU 09-15-2002 09:48 PM
CG for Hotspot
looking for the CG for the hotspot.
Brandon
S HARRIS 09-16-2002 01:06 AM
CG for Hotspot
THE MANUAL I HAVE STATES 135MM BACK FORM LEADING EDGE OF WING AT THE ROOT. SCOTT
Brandon-RCU 09-16-2002 03:35 AM
Thanks for the quick reply.
Brandon
Kelly W 09-16-2002 03:53 AM
CG for Hotspot
Hey Brandon,
I just had my first flight on a HotSpot today at Princeton. This thing can be a real missile and a joy to throw around. I used My Wilcox's CG recommendations, chose a line at 7.25" and set it slightly nose heavy from there (dry). It was very manageable, at that setting.
I also set the elevons up 3/8" in level flight and when a little over recommendations on the elevator and aileron throws. My power plant was a TJT-3000 turned down to 115K, still with plenty of power for this model.
Good luck, you are going to have a lotta' fun with this plane.
Kelly
