tubine connection diagram
does anybody have some kind of connection diagram for turbine showing how throttle / receiver / fuel pump /ecu /batteries / turbine /.....are connected together?
test bench installation photos with good details might be ok as well... one more question... for emergency cut off, how it is done? is it just putting throttle to 0 or by using an electrovalve cutting fuel? |
RE: tubine connection diagram
What turbine in particular...;)....though all basically the same, there are a few subtle differences
This is a MW54 test setup..;) http://www.rcuniverse.com/forum/upfi...66/Rp43592.jpg |
merlin 160...
very nice...this is exactly what i was asking for! thanks.
and...what about the emergency cut off? |
You should have a manual/emergency shutoff valve between your fuel tank and the line going to the fuel pump...
Cheers, |
hpghost,
Hey mate, I have used a servo controlled fuel cut off before in the early Wren / Reaper set up. It was fine but with todays ECU's and fail safes it's not common, although in my opinion still worth it. Once the trim hits 0 it will shut off the fuel selenoid. If you are using a digital trim for the throttle, typical with the 9X i would recommend you set the tranny to have the throttle cut on, in this way it is an instant cut off rather than waiting for the slow response of the throttle trim. You should always have a seperate, manual shutoff valve between tank and pump!! If you want any more info, especially on the Merlin set up or the Wren's come over to my place i live 5 mins from you site office!! Regards Lee |
