Combat Models F16 control throws
hello could someone please give me the control throws on the
combat models f16. I haven't flowen the plane in quite awhile. Inow have to set up from scratch. Thank You |
From the book:
Elevator: 1-1/4" up and down Ailerons: 1" up and down Rudder: 7/8" right and left Cheers! Bob |
I'm getting the F-16N this week. How are these kits, and what engine do you recommend.
Thanks |
I haven't started on mine yet. You can check out this thread, it is talked about a few times. http://www.rcuniverse.com/showthread...threadid=23461
I should be starting on mine this weekend. Cheers! Bobb |
Bobby D -n thanks for the info. I just got the plane all set back up
Sure wish the weather was better so I could fly it. I am running an MDS 68 with pipe and a Cline regulator with an 11-7 prop 14000 rpm on the ground. Hopefully next weekend will be better. |
Keep us posted...
Crash,
Please keep us posted of your experience. I have one that is pending a pipe in order to do the maiden. I'm interested in the cline performance as well as how much runaway for takeoff / landing. Good luck, Edgar |
| All times are GMT -8. The time now is 07:16 PM. |
