RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Hardware (https://www.rcuniverse.com/forum/rc-jets-120/3117023-hardware.html)
DCM 06-28-2005 07:17 AM
Hardware
I'm starting to rig my Crusader. Does anyone know a good source for metal ball links. Something larger that 4/40.
David Hudson
www.dcmodelshop.com
A7Bldr 06-28-2005 10:22 AM
RE: Hardware
David, for some reason I can't get to their website, but I believe that Aircraft Spruce has some nice 5-40 size rod ends. We were going to use them on our A-7 stabs.
Jim
DCM 06-28-2005 10:53 AM
RE: Hardware
Cool, The stabs are what I need them for.
David Hudson
www.dcmodelshop.com
Terry Holston 06-28-2005 03:31 PM
RE: Hardware
ORIGINAL: DCM
David Hudson
www.dcmodelshop.com
David, when ya gonna update your web site??????????????????? Please??????????????:D[8D]
DCM 06-28-2005 04:00 PM
RE: Hardware
ORIGINAL: Terry Holston
ORIGINAL: DCM
David Hudson
www.dcmodelshop.com
Soon grasshopper..........soon [8D]
David Hudson
WhoDaMan 06-28-2005 06:10 PM
RE: Hardware
1 Attachment(s)
Hey Terry:
If you knew how busy Dave is you would give him a hand :D. Hey Dave whats this???????? And No thats not Dave
DCM 06-28-2005 06:28 PM
RE: Hardware
ORIGINAL: WhoDaMan
Hey Terry:
That is a 1/4 scale ch-47 Chinook......[X(] Yes, I'm much prettier that that.[:-]
David Hudson
Countryboy 06-28-2005 06:32 PM
RE: Hardware
1 Attachment(s)
David,
Don't know if this would suit your need's or not.....but you may want to check out these 6/32 ball links from Sierra.
http://www.sierraprecision.com/products.html
DCM 06-28-2005 06:42 PM
RE: Hardware
Thanks Country,
David Hudson
Zagiflyer576 06-28-2005 07:07 PM
RE: Hardware
holy jesus!! what is that thing??? My buddy has the only remaining vario turbine chinhook, and i thought that was bit...but WOW!! Blew me away....
DCM 06-28-2005 07:12 PM
RE: Hardware
ORIGINAL: Zagiflyer576
Just a display model. Only air it will see is by hanging up.
David Hudson
www.dcmodelshop.com
cactusflyer 06-28-2005 07:44 PM
RE: Hardware
1 Attachment(s)
Dave,
Click on:[link]http://www.aircraftspruce.com/catalog/appages/aurorabrng.php[/link]
I bought the both the MW-2 and the MM-2. The MW-2 has 6-32 female threads just like a clevis. The MM-2 has 6-32 male threads. I pulled the picture of the MM-2 off the web-site and I can't seem to find my picture of the other one. Anyway, the construction is certainly sturdy and they should last many airframe lifetimes! The hole in the ball is .125" which makes it correct for a 5-40 screw. I got Allen cap screws from Micro Fasteners. Central Hobbies sells 6-32 titanium threaded rod ends that are bonded into carbon pushrods that should work well. This control system is total over-kill but I think that it is worth it, especially when dealing with a flying stab.
Tell us more about that F-8 landing gear......................
I hope that this helps,
John
WhoDaMan 06-28-2005 08:29 PM
RE: Hardware
1 Attachment(s)
Hey Dave,,,,,,,,,,,, Deb made you some pudding [X(]. Dave I'm Droooooooolinggggggggggggg
DCM 06-28-2005 08:52 PM
RE: Hardware
1 Attachment(s)
Not much to say right now. I sent the gear file to my " gear guy" and the prototypes will be finished soon. The nose will be air and the
main will be screwjack. Main tires are 4.5". The mains will use a common mounting plate for left and right struts. The screwjack cly
will lock the main in the down and up positions.
P.S. Your A-7 looks great. I talked to Peter the other day at work. Great guy.
David Hudson
www.dcmodelshop.com
DCM 06-28-2005 09:00 PM
RE: Hardware
ORIGINAL: WhoDaMan
From the look of that picture of me I better step away from the pudding.:(
David Hudson
