Hotspot CG
Can anyone tell me the correct CG for the Hotspot turbine?
Thanks for any help. |
RE: Hotspot CG
hello
RE: Hotspot CG
The following information came from "Unofficial Guide for building the Hot Spot" PDF file I received from Bob W.
Technical information. CG – DRY Place a strip of masking tape on the leading edge of each wing starting about 6 inches from the vertical fin. Place a ruler along the wing leading edge and butted up against the vertical fin. Measure down the leading edge from the vertical fin and make marks at 7 and 7 1/2 inches. Lift the plane by placing your finger at each location and balance. At 7 inches makes a easy flying plane and 7 1/2 livens it up a little. Make sure the plane is also balanced from side to side. Elevator Throw +/- 1 1/4 - 1 1/2 inches maximum. At neutral, set both up by 3/8 of an inch measured from the wing cord side for wing reflex. No need for dual rate but use expo! Aileron Throw +/- 5/8 inches, Low rate +/- 7/16. Rudder Throw +/-7/8 inch minimum. Airbrake Deflection Approximately 60 degrees. Wing Servos > 100 oz in of torque. Engine Any turbine capable of 12 or more pounds of thrust. Aircraft Dry Weight 18 to 22 lbs. |
RE: Hotspot CG
1 Attachment(s)
Pic from the manual.
| All times are GMT -8. The time now is 12:27 AM. |
