Voltage regulator
Hi I have a R319DPS reciever and 11 servos some digital and some analog. This is installed in a Jet. I need to use a 6v 5cell battery pack since the 4.8v pack is causing a vibration in RPM reading in the ECU if the engine. I also need to use a regulator for this, can anyone recomend one please?
Thanks, Michel |
RE: Voltage regulator
We moved this to the Jets Forum because it can be answered better there.
Probelm solved for the moment, I will go with a duralite package.
Thanks, Michel |
I use these from Bob Violet
work just fine http://www.bvmjets.com/Accessories/bvm_accessories.htm bottom of page on the right |
Before you buy, you owe it to yourself to check out Fromeco. Rock solid, affordable, adjustable voltage, lots of options. The pin switch option is sweet. http://www.fromeco.org/Shop/aRegulators.htm FWIW. Aloha, Woody.
Hi Woody, thanks for the option but I allready closed the deal. I guess for next time...:D
Thanks again, Michel |
You will be VERY happy with the Duralites, I know I am!:D Their service is second to none, I had a problem that was my fault, and they replaced the battery with a larger capicty redundant battery right there, no questions asked! The Duralites have the Cell Balancing and Safe Charge circuitry built in, which to my knowledge gives a balanced charge to each of the cells. In Duralites electric packs with the balancing, you can NOTICE the power as opposed to a normal pack. IMO they're better than any other pack out there, and you can't go wrong with their service either. Thanks Duralite!
| All times are GMT -8. The time now is 02:36 AM. |
