RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Dropping bombs (https://www.rcuniverse.com/forum/rc-jets-120/3403049-dropping-bombs.html)
Fireman1979 09-28-2005 03:17 PM
Dropping bombs
Anybody knows where to find information about this? Or any simple systems to make yourself? Would like to try that very much
Fireman
sandslx 09-28-2005 03:24 PM
RE: Dropping bombs
We use BVM EZ hanger or BVM EZ drops on our Kingcats and F-100s
go to www. BVM jets.com They sell all the components you need to drop bombs.
Justin Sands
Gordon Mc 09-28-2005 03:25 PM
RE: Dropping bombs
http://www.bvmjets.com/Accessories/ezdrop.htm
barneybaru 09-28-2005 04:04 PM
RE: Dropping bombs
To drop them use button valve also available at BVM. Let a micro servo activate the button valve and away they go.
You have to run an air line to the EZ Drop with the button valve in between the air tank and the EZ Drop.
Shaun Evans 09-28-2005 06:09 PM
RE: Dropping bombs
1 Attachment(s)
Hi,
Another option is a mechanical bomb-release mechanism. We make one in two sizes that can be actuated by either an air piston or a servo. Nice thing about it is that there are no air lines to rig if you use the servo method. It takes very little force to actuate the release, also. The clips can be glued or bolted to whatever you want to drop, and they are strong enough to support practically anything you want to hang or drop.
