RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Volt meter (https://www.rcuniverse.com/forum/rc-jets-120/3624361-volt-meter.html)
sirrom 12-06-2005 02:16 PM
Volt meter
Forgive me for asking this because I know the answer is very simple but I can't seem to remember how to do this. I currently own a very nice volt meter that I would like to setup to monitor the voltage that my servos draw. I just can't remember how to wire it up in series with my servos so that I can read the voltage. Call me stupid but I truly cant remember.
Thanks in advance.
Patrick
TommyWatson 12-06-2005 02:39 PM
RE: Volt meter
You can put the meter onto the current scale and place it in series with the posative (+) lead from your battery. set the meter to an appropriate scale. You will need to cut the (+) lead to do this.
Or if your meter does not have a current range then you can place a 1 Ohm resister in series with the posative lead and put the voltmeter accross the 1 Ohm resister. The current is found by the formula I=E/R where E= the voltage read on the meter and R= 1. So for a voltage of say 2volts the current would be 2 amps. The resister should be of sufficent wattage to carry the expected current.
P=I*E so for an expected current of 2 amps the power rating of the resister should be at least 4 watts.
Regards
lov2flyrc 12-06-2005 04:44 PM
RE: Volt meter
Two easy solutions for you Patrick...
[link=http://www.electrodynam.com/cgi-local/SoftCart.exe/new/EDR-201/index.shtml?L+scstore+tqnl8709ff42bc42+1140480954]THIS[/link]
[link=http://dreamworksrc.com/catalog/product_info.php?products_id=278]THIS[/link]
TommyWatson 12-06-2005 05:01 PM
RE: Volt meter
Great stuff Todd, I have been doing this for years with bits of wire and old plugs etc. Your meter is perfect.
Regards
Gordon Mc 12-06-2005 05:12 PM
RE: Volt meter
ORIGINAL: sirrom
Thanks in advance.
Patrick
If you really care about the voltage, then you do NOT connect the meter in series - you connect it in parallel ; you only connect in series for measuring the current, not the voltage.
sirrom 12-06-2005 07:50 PM
RE: Volt meter
Todd,
I wanted an interim solution that I could hook up quickly with minimum expense. Read the PM I just sent you and you will understand why.
Gordon,
Thanks for the clarification. This is why I ask these questions before I attempt to do any of this. .
Patrick.
lov2flyrc 12-06-2005 08:08 PM
RE: Volt meter
Understood Patrick ;).... I knew exactly what you where looking for since you where present when I demonstrated the benifits of having such a tool on hand. 40.00 investment may just save your $?0000.00 plane. I know it has for me.
Tommy... one of those "you wont know how you did without it" tools. Good decision ;)
Regards,
Todd
