RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Speedbrake problems Harpoon (https://www.rcuniverse.com/forum/rc-jets-120/3642695-speedbrake-problems-harpoon.html)
helihover 12-11-2005 05:39 PM
Hello.
I am building the Graupner Harpoon, but I have problems with the linkage to the speed brake. It seem that whatever I try to do it`s possible for me to move the speedbrake door fore and aft when tihe brake is fully deployed. Can anyone tell me if this is normal, of if it`s at fix to this problem?
Helihover
reo 12-11-2005 05:54 PM
RE: Speedbrake problems Harpoon
I've built two of these, (just finished building one for a friend) so the problem you're having is fresh in my mind because I had the same issues. I solved the issue by doing two things.....1) building a wooden frame on the inside of the speed brake to stiffen it up and more importantly 2)..I added a 3rd hinge in the middle and it absolutely solved the problem for good. (I assume your kit is the same as the Comp-ARF Rookies)
If you wish I can send a photo.....PM me required.
Good luck with it....Ron
SAP_2000 12-11-2005 06:55 PM
Hi!
I don't understan excactly what you mean, but I just finished the speed brake on my Rookie II yesterday.
So if if you want, just give me a call tomorrow ( 90013131 ), and we'll sort it out[8D]
Who are you by the way...[sm=confused.gif]
http://image.rcuniverse.com/forum/up...87/Db86459.jpg
CARBUNCLE 12-11-2005 08:42 PM
1 Attachment(s)
ORIGINAL: helihover
Hello.
Helihover
this also strengthens the set-up and reduces slop or unwanted excess movement.
reo 12-12-2005 09:43 AM
sent a couple of PM's with pics.....Ron
