RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Attack of the CLONES! (https://www.rcuniverse.com/forum/rc-jets-120/3820037-attack-clones.html)
EASYTIGER 01-24-2006 07:21 PM
Kangarool, anyone?
http://5822.com/com/chengyutuo/cp.php?nowmenuid=11016
Shok 01-24-2006 07:29 PM
RE: Attack of the CLONES!
gotta love the fiberglass av8r
I'll take extra butter with my popcorn thanks
EASYTIGER 01-24-2006 07:31 PM
Before anybody says "SAAAAAAAAAAYyyyy, that's a copy of the Yellow Aircraft A-4!"...the YA A4 is a copy of the JHH one...
EASYTIGER 01-24-2006 07:33 PM
I have a "Reaper" that came out of the AMD factory(at least the fuel tank was marked "AMD", and it differed pretty substantially from the Mick Reeves one, especially in that it has a glass fuse. Pretty dramatic change from a wood one.
They ended up changing the design around a bit and selling it as the "Draco".
rcguy! 01-24-2006 07:35 PM
I'm holding out for a $530USD Bobcat comp!
You KNOW its gonna happen!
Pass the popcorn please....
Dave
seanreit 01-24-2006 07:35 PM
1 Attachment(s)
It's not that hard to do this stuff yourself.............
EASYTIGER 01-24-2006 07:40 PM
ORIGINAL: seanreit
Yeah, sure. Now go make 72 of them. And box them up and sell them. Apples and oranges.
It's easy enough to splash a couple of parts off an original. Has nothing to do with actual production, where they are making professional plugs and a half-dozen production molds so they can actually set up a production line. So what does your bobcat clone have to do with this?
This is a beeeeeg factory that churns out many arves, you can see their products all over the place.
seanreit 01-24-2006 07:44 PM
ORIGINAL: EASYTIGER
That would be illegal, all I'm saying is it surprises me you don't see more of this cloning going on, not surprised at all to see another site doing it. I know that the Comp Arf Euro has been splashed and remanufactured under at least four different companies all selling basically the same airplane with some minor changes.
I just got a Yellow Twin 18 the other day, and noticed on this site that somoene's already cloned it.
I think learning to work with all the stuff involved in molding and making your own is a fun part of the hobby often underexplored.
clguru 01-24-2006 07:47 PM
ORIGINAL: EASYTIGER
Wrong!!!
completely different animal
Also about ten years apart.
Dan
EASYTIGER 01-24-2006 07:55 PM
ORIGINAL: seanreit
ORIGINAL: EASYTIGER
Yup. Who is cloning the Eurosport?
EASYTIGER 01-24-2006 07:57 PM
ORIGINAL: clguru
ORIGINAL: EASYTIGER
Wrong!!!
Dan
Nope! The first YA A-4 (and F-4) were copies of the JHH designs, except they had presheeted foam wings. The newer versions have different intakes and have deviated to a fairly "different animal". Bob Violett designed the first A-4. Sold it to JHH.
Jeff Foley 01-24-2006 08:01 PM
You guy's are missing the point......they just wanted to show off the fact that they can make BLUE tires. (check out the A-4)
EASYTIGER 01-24-2006 08:04 PM
Totally sexy! They would not dare make purple ones, though!
NickC5FE 01-24-2006 08:08 PM
HEY SEAN, which mold making methid did you opt for on that "CLONE" HAHA. I am going to start a AD-Size F-16 and am unsure which one to use. Sand or epoxy. My buddy KIM (Jetmax) uses the epoxy and glass method. It seems as though the sand would be heavier, but easier. Thanks, Nick
seanreit 01-24-2006 08:08 PM
Don Kanak helped fund a clone, and Modelbau did one. I forgot the name of one company that did a splash of the Euro.
Anyway, none of them had pink wheels that I know of.
EASYTIGER 01-24-2006 08:09 PM
Say, here are the specs on the Hawk:
The Red Arrows R/C model airplane
Specifications
No: YH030
Wing span:55 in / 1400mm
Wing area: 967sq in /62.4 sq dm
Flying weight: 10.50 lb / 4800g
Fuselage length: 56.3 in / 1430 mm
Engine Required: 2c 0.46-0.91 cu in
4c 0.91-1.20 cu in
Radio Required: 7 channels,9 servos
Four stroke ducted fan? Man, what will they think of next!
ghost_rider 01-24-2006 08:10 PM
ORIGINAL: seanreit
OMG Sean, you did not post those pictures did you? (lol)
EASYTIGER 01-24-2006 08:16 PM
ORIGINAL: seanreit
Are you quite sure? What brands were they sold under?
EASYTIGER 01-24-2006 08:17 PM
ORIGINAL: ghost_rider
ORIGINAL: seanreit
Keep wondering why! The Violett fans have been known to get viollent!
gregmax 01-24-2006 08:18 PM
ORIGINAL: EASYTIGER
Wankle [>:]
seanreit 01-24-2006 08:19 PM
I used Ultra Cal 30, I've done resin and sand, Ultra cal 30 is by far the easiest, but the molds on the F-16 would weigh about 200 lbs, and that's no joke, my bobcat clone molds weigh about 50 lbs each half. It's basically concrete. This is the first time I've used the stuff, if I was gonna do it again on a fuse, I would have chaanged the way I plugged the original. But the output is sound.
Ben, from what I understand it's been leaked what I was doing so many times before I posted it in another thread that it didn't matter.
I don't think I'm on the list anymore for the ultra bandit though ;)
EASYTIGER 01-24-2006 08:21 PM
ORIGINAL: gregmax
ORIGINAL: EASYTIGER
Wankle [>:]
No need for name calling!
seanreit 01-24-2006 08:21 PM
I own around 15 grand of violett's stuff, an airplane he doesn't make or support anymore for me personally to fly ain't gonna hurt anybody. So up in arms violett fans, I don't think that's gonna happen.
NickC5FE 01-24-2006 08:22 PM
Sean, the ultracal would be that heavy? or the sand....thanks
ghost_rider 01-24-2006 08:23 PM
ORIGINAL: seanreit
This is my first time hearing it. Oh Well....good luck
....ghost_rider......out......
