Brake question
Just wondering, Does anyone put a lubricant on there BVM brakes so that the tires dont just lock up....????
David |
Brake question
David,
Get a tube of white lithium grease and smear some on the hub part of the wheel. Take a paper towel and remove as much as you can so that you have just a thin film of grease left on. Make sure and lube your axles while you are at it. |
| All times are GMT -8. The time now is 04:46 AM. |
