ONE QUESTION ONLY BEFORE I EXPLODE
Dear Sirs.
please i need your opinion on somethink cose i maybe must move to beginers forum .... WHEN you want to remove an air line from a fitings niple...and you cut the line out ARE YOU CAREFULL NOT to damage the cone of the niple cose this will cose airleak next time OR IT DOSENT MATER??????????????? >>>>>>>>>or HOW MUCH MATTERS?????????? thank you for your time spendin reading my post and reply cose this is important to me cose right now im very mad....probably the next days coming ill let you know what is going on thank you again |
RE: ONE QUESTION ONLY BEFORE I EXPLODE
Cutting it off at the nipple can score it and cause leaking, yes
Ya, it matters, I always take a pair of dikes and pinch it from the side, you can pinch some away from the nipple and then crunch through the air line, then it will smoothly come off.
Been doing that for years and never a leak caused. Regards, Sean |
Of course what really keeps it from leaking is this:
http://dreamworksrc.com/catalog/prod...roducts_id=465 Bob |
If I can't simply pull the airline off, then I take a very sharp xacto blade and carefully cut only partway through the airline, along the centreline of the nipple. Then I pull the airline at 90 degrees to the niple, putting stress on the line so that it splits along the cut-line.
Dunno how clear that explanation is. |
I'm using a heat gun, then just pull and it comes off
ORIGINAL: rhklenke Of course what really keeps it from leaking is this: http://dreamworksrc.com/catalog/prod...roducts_id=465 Bob this is only to HOLD your line on the fiting dont pop out from the presure. the SEALING is done by the cone shape of each niple |
George, it is well known that the nipple works, However, you're gonna have a hard time telling me that putting safety wire on the nipple doesn't help contain any leak that might occur.
You asked the opinions, last thing you need to do is come on here and tell someone he's wrong, I mean, something so simple as an airline on the nipple, and apparently you F'ed it up. You're not the first or last, but I have seen many a tidy installation that someone took the time to safety wire their air lines. It is common enough practice. |
carefully touch a warm-hot solder pencil around on it, wiggle, pull it off.
ok here i go:
SO EVERYBODY READ THIS AND DONT MAKE MY MISTAKE ..... waiting a month and a half , for my order to come that in the order where tanks of airpower and T airfitings of the same company. i must say that no problem had with any of the rest of the products or the company i placed the order just with the spesifick airpower products so after a long time i had to fly i get two days of my work and start servis my jet. all airlines out and new placed. rerot them. and cut them on presise lenth. place tanks on nose and fitings PLACE IN EACH NIPLE OF EACH FITING WIRE.....and we mean alot of fitings including doors and so .......only this took me an evening work it all out prepare it and on final i gaved air presure to check everythink. "WHAT THE..."[X(] [:@][:@] IT WAS LIKE I WAS DREAMING AND I LEAVED MY WORST NIGHTMER[:@][:@] do you know the sound when you have a air leak from a bad conaction .... well this sount was ALL OVER MY JET LAAAOUD [:@][:@] :(:(and i was so ooo panik cose i coulnt unterstant what did i do whrong:(:( so I ASK YOU what i like to ask IS IS ANY ONE THERE ON AIRPOWER HAVE EVER BUILD NOT A JET BUT AT LEAST A PLANE WITH RETRACTS?????????? >>BECOSE: it seams that THEy GRAB THE NIPLES TO PLACE THEM TO THE FITING WITH PLYERSS!!!!!!!!!!!!! AND THEY DESTROY THE CONE PART OF THE NIPLE. am i so whrong in that or its so hard for them to unterstsan that this is not bad for there sells but the product is USELESS ...........sorry people i talk like that....:( but no jet stores here to buy somethink so i must wait some times alot for my goods to arive thro post.... anyway i go to rest thank you for your time spendin on my post |
I use the heat method too. If you are in a confined space and can't use a heat gun, touch a soldering iron to the end of the tubing and it will pull right off.
ORIGINAL: seanreit George, it is well known that the nipple works, However, you're gonna have a hard time telling me that putting safety wire on the nipple doesn't help contain any leak that might occur. You asked the opinions, last thing you need to do is come on here and tell someone he's wrong, I mean, something so simple as an airline on the nipple, and apparently you F'ed it up. You're not the first or last, but I have seen many a tidy installation that someone took the time to safety wire their air lines. It is common enough practice. sorry for my behavior seanreit....[:o] i m not new and i always use safety wire.... just i spent too many hours and find at the end that the product wasent as it soposed to be.... tomorow first think ill sent you some photos to see it for your self ...cose this not only leaks...when you try to use wire it cuts your line! sorry again didnt mean nothing bad.... ...i think i pay one time only for festo and im done..?... just dont want to crash it thats all... take care everybody |
Sell the jet [8D]
ORIGINAL: DelGatoGrande ORIGINAL: rhklenke Of course what really keeps it from leaking is this: http://dreamworksrc.com/catalog/prod...roducts_id=465 Bob this is only to HOLD your line on the fiting dont pop out from the presure. the SEALING is done by the cone shape of each niple In addition, in a lot of installations, there are air lines with tee's or fittings, that wind up near the turbine or tailpipe and these can easily leak when the tubing gets warm and loosens its grip on the nipple - even if it doesn't actually come off the nipple. Safety wiring these will also greatly reduce the occurence of leaks. Bob |
Sounds familiar, I bought some airpower T's las year. Almost all of them leaked so I threw em in the trash and replaced with Robart and Spring Air parts.
1 Attachment(s)
Since Geroge brought this to my attention, I went and check my inventory of Airpower Tee fittings checking for the markings he describes. I did find a bag that had fittings with these markings. It took a magnifying glass for me to see them but indeed, there are some small scores in the brass nipple. What I found strange... I have literally sold thousands of these Tee fittings, they are one of our most popular items, and never had one complaint of leaks caused by the fittings. I decided to see if I could get one to leak. Took the worst one I could find in the bag of 10, seen in pictures one and two (had to set the camera to Macro for these shots, scores look pretty big here). I tied two of the ports together with some Dreamworks airline, hooked the third to my hand pump and pumped it up to 160psi.... That was an hour ago, still sitting at 160psi. I have wiggled, pulled, flexed the lines in every direction....no leaks.
What I have found is the brand of Airline used makes a huge difference! I was able to get the cheap Asian translucent type airlines to leak on this fitting by bending the line close to the barb BUT.... I plugged that same airline onto another brand metal Tee we carry and I was able to get leaks on that one using the same method as well. Dreamworks airline is made to spec from a heat resistant material with thicker walls and slighly smaller ID for tight, leak free connections. I would be willing to bet George is using a low quality Asian (usually translucent) airline which is more likely the cause of his airleaks. We stopped using this type of line several years ago for this very reason... George...I would be happy to replace your Airpower Tee fittings with Tamjet metal Tees if you wish although I doubt this will resolve your leaks. Let me know what you would like to do... Todd |
1 Attachment(s)
thank you Todd
you are great! here is the photo i promished...strange part is that this is not the first time i use this i have some old ones on other planes...and they are perfect with no mark on the nipple... ....but realy cant redo all this work again so i go festo all of them cant risk it ...i like perfection on my work mail me your address so i sent them thanx again |
George,
Any of those damaged tees you don't want, send them to me. I'll put a couple of wraps of safety wire around the line behind the barb and fly 'em... Bob |
sure bob can mail them to you
if you like to buy them from me ...the damaged ones tho ill sent them to Todd becose i deside to make changes on all system i have many good fitings i dont need cose ill go festo on there also 3 or 4 airpower valves ...i got the jetronicks now .....so if you like them let me know..all perfect contition ....also about heat gun or whatever give heat ....i dont know..i dont know if they use any threat glues that it posible to be damage by the heat... anyway thank you all |
sell the plane, it leaks
Ah, going to Festo fittings - that should work :eek:
Good luck... |
I just use a set of angled mini shears an pinch the line at the top without ever coming in contact with the T. Works great .. Here is a link to the ones I have
[link=http://www.ares-server.com/Ares/Ares.asp?MerchantID=RET01229&Action=Catalog&Type=P roduct&ID=82526]Mini shears[/link] |
ORIGINAL: rhklenke Ah, going to Festo fittings - that should work :eek: Good luck... George, Is this the airline you are using?? http://image.rcuniverse.com/forum/up...32/Vp38303.jpg |
I have never had a problem with ANY of my installations about leaking air, i simply make sure to cut the tubing squarley and make sure it is all the way on the fittings... I have used plastic BVM fittings and the plastic robart and spring air fittings, I have never used the metal fittings yet..If the fittings are marred from improper cutting or line removal this may be your problem also you may have the wrong diamator line..These guys have covered all the possible ways that you should remove a line if you have it messed up.. I have always used the robart line but latley i have used the colored line from Todd, Still no leaks.. Make sure you are using the right diamator line on your install, i "think" air line is 3mm or just a shade smaller, NOT the 4mm you use for fuel... Russ
wow, a 24 posting thread on airline and tees.....
| All times are GMT -8. The time now is 02:16 AM. |
