BVM .91 / BVM mixture settings ?
I lost my high speed settings on my bvm mixture valve ..... how many turns should i open it to start with ?
thanx Wojtek |
Set the mix SERVO at mid travel. Close the mix control valve all the way and open four turns. start engine, let it warm up, full throttle, turn needle till max rpm, open 1/4 trun richer, try your servo mix for max lean and max rich..you're done!!!
thanx !
Wojtek |
