what servo for fan jets
i have 3 byron jets:f-86d,mig15,and a f-16 what servos should i use?? i was planning on using hitec 425's in the mig and the f-16, the f-86d has futaba 3004's and 3003's. i read that these may not work. i have no pcm radios and i plan on using 6.0 volt batteries what is a good servo that will handle my jets?? thanks donniercjet
RE: what servo for fan jets
None of those are high performance jets, they will fly fine on standard cored servo's, if you have 60 + ounces of torque you should be fine. The stab on the F16 being full flying may need more, I'm sure somebody who's built one will chime in, but I have known many people that had the F16's and Mig and all used standard servo's. These jets were around in the days that 45 ounces of torque in a servo was a lot and flew fine.
| All times are GMT -8. The time now is 02:08 AM. |
