RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   What company does the 4 axis thrust (https://www.rcuniverse.com/forum/rc-jets-120/4027860-what-company-does-4-axis-thrust.html)
seanreit 03-13-2006 09:05 AM
Vector system for the Rookie II??
BlackCloud 03-13-2006 09:18 AM
RE: What company does the 4 axis thrust
I think its "Shakira";) :D
SAP_2000 03-13-2006 09:19 AM
4 axis... Horisontal, vertical and whats the other two...;)
I was told C-ARF is going to release the two axsis vector system as a option in the near future. I believe the two axsis thrust you have seen on the new Rookies lately have been made from scratch by C-ARF reps.
I know Tam used to make two axis thrust vector for the old Rookie some time ago, but not sure if he still does....?
When it's availiable, I'll be first in line...:D
causeitflies 03-13-2006 09:28 AM
ORIGINAL: SAP_2000
Neutral and reverse of course:eek:
...and why aren't thrust reversers allowed?
lov2flyrc 03-13-2006 09:43 AM
1 Attachment(s)
Dreamworks will have Two dual axis nozzles available shortly...
First nozzle is a dual axis single wall, will retail for 185.00
Second nozzle is by Tamjet, a dual wall dual axis which retails for 229.95
Both should be in stock before months end...
Todd
seanreit 03-13-2006 09:44 AM
I can't find them on Google, anyone got a website or contact? After seeing the video posted at FL Jets where that Rookie two spun in yaw, yesterday I ripped out the CARF thrust vectoring system completely and I'm gonna hold out for the four way.
lov2flyrc 03-13-2006 09:47 AM
Sean,
I'll send you my sample pipe to use ;-)
Todd
TREADSTONE 03-13-2006 09:50 AM
1 Attachment(s)
Pick of Tam's Rookie DA TVS pipe ..... $230.00.... Dual axis is all your gona get;)....or need for that matter.
....or a link to a European site...Swiss believe..or German..;)
https://ssl.kundenserver.de/s9981668...120000023%3D29
seanreit 03-13-2006 09:50 AM
Todd, did that one come in that we spoke about? What's the status of my Merlin?
seanreit 03-13-2006 09:51 AM
PERFECT! MAN, I'VE GOT CHICKEN FLOPS ON THE BRAIN!!!!!!!
seanreit 03-13-2006 09:54 AM
For clarification, I meant 4 way, not axis, sorry for giving you guys ammunition this morning, damn :D
lov2flyrc 03-13-2006 10:18 AM
ORIGINAL: seanreit
Yep, Sure is... ;) Merlin is out of storage, will give it a quick test run before I ship it out.
cactusflyer 03-13-2006 10:56 AM
..It's obvious, gentlemen, the third and forth axises are for flight in the forth dimension...............or in Texas, as the case may be!
John
CARBUNCLE 03-13-2006 03:35 PM
1 Attachment(s)
here is how they are being home-made , very simple. mines a little scruffy after a year or so of use. and btw it's upside down in this pic.
Woketman 03-13-2006 07:33 PM
Carbuncle, could you post a much larger photo, plus several more views? Thanks.
CARBUNCLE 03-13-2006 11:01 PM
1 Attachment(s)
Sure, but my cam batts are shot, so these 2 will have to do till I get to best buy.. and motor is out to for a check up. 1st pic is top side up, 2nd is up side down. My set-up is a little crude due to my limited machining skills and tools. But it's safe, all screws have loctite on them and most all nuts are stainless all metal lockers. All wear areas were coated with graphite paste. This rig has 150 flts on it and still no slop..
