RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   AV-8 Harrier plans ? (https://www.rcuniverse.com/forum/rc-jets-120/40943-av-8-harrier-plans.html)
Guardian 01-25-2002 08:28 PM
does anyone make a set of Harrier plans ?, what scale are they in ?, thanks
mec 01-26-2002 06:25 PM
maybe of interest
http://www.excitingrcm.equology.com/
mec
Terry Holston 01-26-2002 07:44 PM
Then again, maybe not. Sounds like another one of those bogus Jet manufacturers that is trying to get started with your money?!? ;)
FLY V/STOL 01-26-2003 02:47 PM
Guardian,
Im also interested in building a Harrier. Im currently up at MCAS Cherry Point flying these aircraft, and am planning on visiting the boeing rep to see what I could get form them. Also there is a Harrier pilot in our club who has a beautiful set of plans that includes all the formers, ribs, spars etc. However he is currently en-route to the desert so I wont be able to get them any time soon. I plan to build a STOL (short take-off/landing) instead of a true V/STOL version. The pilot I mentioned had built one that had full ducting for vertical flight, but the ducted fan powerplant was grossly underpowered, and he miscalculated the CG which led to a interesting but short flight. If you plan on trying one that will hover you will most likely need a turbine powerplant to generate the massive amount of thrust needed.
You can email me with your thoughts at [email protected]. Im probably going to try a foam/fiberglass EDF version.
vtol_guy 01-26-2003 04:09 PM
i'm not building a harrier right now but i do have experience in VTOL planes.
If anyone is planning/wanting to build a harrier then this site might be very useful for starters
http://geocities.com/v22chap/vtol.html
click on the guy that has a jet VTOL.
some things there should help you
Also i think the best thing to recommended is build a testbed first, dont go jumping straight into a harrier, build something like the guy with the jet VTOL has done, it'll make things easier for you at the end of the day.
