cylinders?
Hi all I need a set of 1/8" , 1/4" , and 1/2" pneumatic cylinders, where can I get them ?
cylinders?
sources for pneumatic cylinders...
Hi Guardian,
Here's a few industrial sources to try. They usually have a local dealer in most areas, probably listed on their web sites somewhere. I've had some good performance from the SMC stuff but it can be expensive. Good luck. :) Kelly ---------------------------------------------------- SMC: http://www.smcusa.com/sections/products/actuators.asp American: http://www.americancylinder.com/ Bimba: http://www.bimba.com/ Festo: http://www.festo.com/INetDomino/coor...e90037be52.htm Bosch: http://www.boschfluidpower.com/produ...cylinders.html |
cylinders?
Thanks guys I just need some cheap 1/8th " to 1/4" cylinders all they are doing is opening a canopy.
cylinders?
Try Century Jets. They make some inexpensive small ones. Or BVM theirs are a bit more. Both work fine. Or you could make your own. :D
cylinders?
How would I make my own ?
| All times are GMT -8. The time now is 10:23 PM. |
