new version gripen
any ideas on if this setup is good, or any thoughts on this set-up with the p-60 in the tail, or whwn it will be available, and color schemes. thanks ahead of time.
RE: new version gripen
Check out the video...
http://www.jetsrc.com/videos/Gripen02.wmv This one is powered by an Artes Bee 14lbs and the turbine is in the tail. You can see that excelent power and performance is achieved. The P60 is 13 lbs of thrust, I guess 1 lbs won't do much diference, so you should do ok with it. Michel |
| All times are GMT -8. The time now is 12:09 AM. |
