Sniper Setup
Hey Guys,
I need some general feedback from people that have or have had the HET Sniper. I am going to get a all white one and add a operating rudder and retract system in it, any ideas? Also I want a very hot setup as I will be dissapointed if it does not GO! What are the best setups or "the" best, etc. Never messed with edf's before so I thought it would be fun to play with. |
RE: Sniper Setup
Skymac, you should post in the EDF forum , or check out RCGroups. The Sniper is a nice little jet and will go like a rocket if properly equipped. But there is barely enough room for the basic equipment. If you try to add retracts and rudder you will have a problem. It's all about weight with edf's. You might want to look at the 90 mm size jets [ the next size up ]. Jepe , Aeronaut makes some nice stuff. Check out warbirds.com or ductedfans.com. Doug
| All times are GMT -8. The time now is 04:56 AM. |
