RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   SMALL Bypasses (https://www.rcuniverse.com/forum/rc-jets-120/424431-small-bypasses.html)
mr_matt 12-17-2002 07:28 PM
SMALL Bypasses
Hello guys,
What are the current sources for the old RAM 500 size bypasses? I know BVM makes one, I am looking for something to fit a Viper.
Also, how are they mounted? Does everyone use the straps? Does anyone have a rigid mount for the RAM 500 sized motors?
THanks
Matt
Ehab 12-17-2002 08:03 PM
SMALL Bypasses
Hey Matt;
I think Tam has a 500 size bypass, check him out. 408-2271767
Cowdog 12-17-2002 08:20 PM
SMALL Bypasses
I've heard different opinions on a Bypass for the 12lb turbines. Some say they are worth it, others say it creates problems for the engine..
Anybody have experience with this setup?
Hank
mr_matt 12-17-2002 08:23 PM
Bypass
I saw someone who had a small turbine is a BV sport jet at Florida, I can't remember the installation. I think it was Gary Mueller's
jason 12-17-2002 08:46 PM
SMALL Bypasses
I was at florida jets with my wren 54 maverick. It has the BVM RAM500 bypass and Gary mueler inlets, double walled pipe and kevlar tanks. Absolutly perfect with 10hours plus run time with this setup.
jason
KevinM 12-17-2002 09:17 PM
SMALL Bypasses
Trim has a bypass and double walled pipe set designed around the SimJet 1200AES. (Meant for their F-86.) I'm currently retro-fitting the set into a Yellow F-16. We had the bypass/pipe sets on display at Superman 02 at the Great Northern Models tent. And like the rest if Trim's products, they're highly affordable!
Turbulence 12-18-2002 01:23 AM
Gary Mueller
Gary sells both the By-pass and engine mount you are looking for. I think TAM tries to keep them in stock
Turbulence
