RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   FADEC Data Terminal Extension (https://www.rcuniverse.com/forum/rc-jets-120/4261886-fadec-data-terminal-extension.html)
747drvr 05-10-2006 09:37 AM
Hi Guys,
Does anyone know how to make an extension with male and female ends to allow me to plug the data terminal in away from the FADEC . Ideally I would like to be able to make a custom length . The cable is very similar to a phone cable . I believe it may be an RS 232 cable.
Marc
Dave03B 05-10-2006 10:05 AM
RE: FADEC Data Terminal Extension
I thought about making my own too. In the end I bought one from Wren. 1ft extension is £8, but other lengths are available to order.
747drvr 05-10-2006 10:24 AM
I wonder if it's something that can be sourced at an electronics store ? It would save having to mail order.
Marc
Gary Arthur 05-10-2006 11:03 AM
Try Sayal electronics in burlington.
cairoman 05-10-2006 11:31 AM
Network cable with RJ45 male plug on one end and RJ45 female plug on the other end.
Regards,
Chris
TREADSTONE 05-10-2006 11:35 AM
Its an RJ 45 connector on the end of the HDT... You can get straight male/female adaptors or extensions ..... Or you could buy the RJ 45 to USB (FADEC to PC/laptop) DATACABLE (black in photo) and use whatever length USB extension you have lying around.... at work ....:Dor at home...;)
http://f5.putfile.com/5/12912132474.jpg
lov2flyrc 05-10-2006 11:36 AM
Already available...see here:
http://dreamworksrc.com/catalog/prod...roducts_id=662
We also carry ECU extension cables in 12, 24 and 36.
Todd
747drvr 05-10-2006 07:03 PM
Hi Guys,
Thanks for all the helpful responses .
Marc
Wayne22 05-10-2006 07:14 PM
Marc... I got Wren to do up a custom one for me (for the AV8R). All I found commercially was male/male ends. You can buy an femal/female adapter (which I did - twice ) but it didn't work. The one from Wren worked first time....
TommyWatson 05-11-2006 02:07 AM
If you want a custom extension lead the Extension that Todd sells can be shortened easilly. The leads are soldered to a small PCB. I have shortened two of mine.
Regards
Kelly W 05-11-2006 02:37 AM
ORIGINAL: nony
Hey Wayne,
That's due to the way the network cables are wired up. If you do a simple resistance test on the leads, you'll see that the inputs are not necessarily linked to the outputs you expect. Bring the parts to Princeton later this year and I'll re-wire them for you if you like, assuming we can carefully break open the adaptor casing...
I've seen the necessary components here in Vancouver for a few bucks only... I'm sure most good quality electronics shops would have the necessary parts to make this cable for no more than pocket change.
Kelly
Koenieboy 05-11-2006 06:21 AM
I took a old network-card from a PC, soldered the female-end off the card. Than a took a short Lan-cable and on one side I cut off the male-end and soldered the female to it.
One thing you have to look after is that you solder straight-straight. So 'wire 1' is also 'wire 1' on the other side.
or you buy this (http://www.alternate.nl/html/shop/pr...?artno=RDLZ15&) and a LAN-cable.
You can get that connector by your local computer-store.
747drvr 05-11-2006 06:29 AM
More good tips ! Thanks !
Marc
lov2flyrc 05-11-2006 07:32 AM
Note: the data extension I sell also remotes the indicator/status light as well as the Data Terminal....
digitech 05-11-2006 09:53 AM
ORIGINAL: lov2flyrc
ok to make even a better deal if you order ours you get a pair of wooden shoes for a disount[8D]
TREADSTONE 05-11-2006 10:03 AM
..OR a sleepover in the van at Jetpower 2006...:)
digitech 05-11-2006 10:11 AM
ORIGINAL: TREADSTONE
a yes the old van
i ordered up 2 table,s for the meeting i will bring the beers.
if you fall over there you can sleep under the table
Wayne22 05-11-2006 09:14 PM
Kelly, that is exactly what I found... It is not an issue any more. The Wren cable works just fine.... not that I will be using it any time soon with project "X" just about ready to fly......:D
TREADSTONE 05-12-2006 12:38 AM
O.K :)... Spill the beans....;)
