wich turbine is better?
the Simjet 2300-25 AES GE or the jetcat P60/80/120 for the Avonds F-16?
I want a turbine engine that are sounding like the real GE in the F-16:D Eric |
RE: wich turbine is better?
the best turbine is the one that starts and runs everytime not the noise it makes, jetcat has the most support out their and lots of help s/jet is not the most popular in the usa , no real negative feed -back. jetcat is usually less expensive, also. the tailpipe configuration will have the most effect on your sound, anyway [sm=cool.gif]
If you want noise and high fuel consumption get a Ram 1000. :) V..
I have had both Simjet and Jetcat. I like the Simjet better than the Jetcat mostly because of the throttle responce is better on the simjet. For support I have had not much luck with Jetcat, and I will leave it at that.
Both turbine have been available for a relative long time. Both brands are good. Get one were you feel confortable with your 'local' support.
