RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Skymaster Gripen ARF PLUS (https://www.rcuniverse.com/forum/rc-jets-120/4267474-skymaster-gripen-arf-plus.html)
JetsRC 05-11-2006 05:39 PM
1 Attachment(s)
Hi guys, this is the new SM Gripen ARF PLUS, it just got here for a customer. Finishing is awesome, all parts fit perfectly and the new hinging is great. Here are some pictures after about 5 minutes out of the box. It will be powered by a Wren 54 MK3 installed in the tail. No Tail pipe...
Michel
hnflyer 05-11-2006 06:02 PM
RE: Skymaster Gripen ARF PLUS
Extremely Beautiful Plane [:-]
seanreit 05-11-2006 06:17 PM
Can someone confirm, my guess is that the "new" or "plus" airplanes, are they just going with Rohocell and Live hinging, similar to what Composite Arf and others have gone to?
lov2flyrc 05-11-2006 06:29 PM
ORIGINAL: seanreit
Negative Sean.... Different process, higher quality and stronger than the C-Arf structures.
ChuckC 05-11-2006 06:35 PM
VARTM perfected then?
Seems liek the way to produce things these days in composites without over weighting the pieces...
PLease tell, if it's not a "secret".
I've noticed that a bunch of the major composite airplane manufacturer's are re-tooling, that is besides having to.
dragonpilot 05-19-2006 02:35 PM
Mdurand,
Can you describe the difference between the plus and the regular one, I'm interested, Thanks
JetsRC 05-19-2006 03:04 PM
I have never seen one of the older ones so I will compare to other SM models I have seen first hand... From what I saw in this one, first everything fits perfectly. There are no aluminium spars for the wings or other surfaces, it is all a solid carbon tube, much lighter.... There are no hinges in the elevons or rudder, it is called active hinging. Similar to the Comp ARF stuff but higher quality and more strengh like Todd said. Because of this you don't have to hinge the elevons or rudder, the hole setup is done for you. The airframe is lighter than previous ones. Also with this one you can install a 14lbs turbine on the tail of the jet, this eliminates the use of a pipe. This is how this one is going to be setup for the owner. Al formers are perfectly glued, no missed spots. The general finish and work in the model is awesome, no seams or weird finishing problems are seen and the model is very soft and smooth. I would personally give it an A++ to this one.
Perhaps Eric or Duke from Airpac can fill us a bit more. I know Duke has flown this bird allready...
Hope this helps,
Michel
dragonpilot 05-19-2006 03:28 PM
Is this the version on sale at Airpac and will a P-70 fit in the tail on this one.
also, are the control horns glued in already?
JetsRC 05-19-2006 04:21 PM
I guess eric or Duke should answer this one...:D
The control horns are not glued, you have to do that yourself.
lov2flyrc 05-19-2006 05:26 PM
No...the sale is on current stock only (sparks built versions). Currently, there are no ARF Plus versions in the states but can be shipped direct from the factory if desired. P-70 will fit in the current version but not "In the Tail" like the updated kit.
Todd
Aero65 05-19-2006 06:32 PM
Hello
The Arf Plus Gripen can mount the P-60 or Artes Super Bee in the tail, Although the P-70 might fit it will require lots of nose weight to counteract the weight of the turbine.
I really loved putting the Gripen together and it was very easy and Fast to assemble. I started Friday afternoon and flew it Sunday, with gear doors! It is so awesome to have those live hinges with the lower edge gap seal on the flight surfaces, Im just so spoiled now.
Our P-70 had to go back for service due to foreign object injestion so I installed my Simjet 1700 SP 20 lbs of thrust Wow the dry weight of the Gripen is 18.5 lbs with full uat, and when you hit the throttle man it go's
I will try and get some video of it this weekend and post it.
Servos
Elevons JR-8611a, or JR-9411
Canard HS-5945, or JR-8611a
Rudder HS-5125, or JR-168, or Mulitplex Super-Fl
Steering any std servo.
Jettronics valves and seq
JR-10X R2000 receiver.
AirPac Models 05-19-2006 06:33 PM
1 Attachment(s)
ORIGINAL: dragonpilot
As Todd & Michael explain, the new ARF Plus version is very different then the currently one. (current version is on sale now) It much lighter and stronger. We have an new one been test for while. The current version is about 20lb. to 21lb. with P-70. The new one with the same set up only about 18 lb. Beside the weight reduce, we are very satisfied the quality of surface finish. The joining seam are almost invisible. It's a dream plane.
SJN 05-20-2006 03:40 AM
Are these new plane without panel lines ?
AirPac Models 05-20-2006 04:08 PM
The new Skymaster ARF Plus still have panel lines as usual
JetsRC 09-05-2006 11:02 AM
1 Attachment(s)
Painting is almoust finished, we hope to make the maiden pretty soon. The scheme is a variant of the swiss F-5, the customer wanted something that was going to be easily seen and great looking... I think the painter did an incredible job....;)
avicom 09-05-2006 05:00 PM
One question about the ruddder hinge in the new arf-plus series. Are they live hinge just in one side like the bandit-arf? Any pics of the rudder hinge method?
Rgds,
Alejandro
joeflyer 09-05-2006 05:10 PM
What engine is going into it?
I'll look forward to the maiden report.
Joe
JetsRC 09-05-2006 05:12 PM
Hola Alejandro, and yes the rudder has also live hinging. I asume it is similar to the bandit since I haven't seen one...[:o] This is not the rule for all the ARF PLUS as the F-16 1/8 has normal hinges for the rudder.
Saludos,
Michel
JetsRC 09-05-2006 05:14 PM
ORIGINAL: joeflyer
Joe
Hi Joe, this one will have a Wren 54 MK3 (14lbs) mounted on the tail.
Michel
avicom 09-05-2006 05:16 PM
Gracias Michel, I hope that the one I'm keep my eyes on have the center line rudder!
Saludos
Alejandro
AirPac Models 09-05-2006 05:51 PM
1 Attachment(s)
Alejandro ,
The new ARF Plus Gripen have live hinge for rudder too. We have new ship that has arrived, due to limited shipments and we already shipped for people pre-order, our stock is running low. Please feel free to contact me if your interested....
AirPac Models 09-05-2006 06:00 PM
Michel,
The color scheme looks very nice. Red/white is more noticeable while flying. Swiss F-5 color scheme is one of my favorite color, the way you put that plane together is very wonderful.
JetsRC 09-05-2006 06:03 PM
Thanks Eric, they guys at the shop have done a very good job and the mods to the paint in the wings area is very nice. The owner (not me) is very happy with it. We hope to make the maiden some time next week.[8D]
Michel
avicom 09-05-2006 06:34 PM
ORIGINAL: AirPac Models
Alejandro ,
Eric, sent you a pm!
rgds
Alejandro
avicom 09-05-2006 06:35 PM
Michel, keep us inform about fligth report and video!!! Good luck in the maiden.
Saludos
Alejandro
